2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Use the Task Manager to load an XML file that defines tasks and their attributes.
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Writes groups to HyperMesh.
Sends the size of the main box of a group to HyperMesh.
Sends a component ID to a group's main component list.
Writes contactsurf entity as part of group entity main definition.
Writes the main definition of a group to HyperMesh.
Sends a set’s ID to a group's main set list.
Sends the size of a secondary box of a group to HyperMesh.
Sends a component ID to a group's secondary component list.
Writes contactsurf entity as part of group entity secondary definition.
Writes the secondary definition of a group to HyperMesh.
Sends a set’s ID to a group's secondary set list.
Writes a basic rigid wall to HyperMesh.
Writes a MADYMO coupling definition of a rigid wall.
Writes a cylinder definition of a rigid wall.
Writes a planar definition of a rigid wall.
Writes a prism definition of a rigid wall.
Writes a sphere definition of a rigid wall.
Writes a motion definition of a rigid wall.
The list of deprecated hminlib functions, and the new functions to use.
The list of undocumented hminlib functions.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
