2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Use the Task Manager to load an XML file that defines tasks and their attributes.
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Transfer metadata of type date to HyperMesh.
Transfer metadata of type double to HyperMesh.
Transfer metadata of type array of doubles to HyperMesh.
Transfer metadata of type entityid to HyperMesh.
Transfer metadata of type array of entiyidtypes to HyperMesh.
Transfer metadata of type integer to HyperMesh.
Transfer metadata of type array of integers to HyperMesh.
Transfer metadata of type string to HyperMesh.
Transfer metadata of type array of strings to HyperMesh.
The list of deprecated hminlib functions, and the new functions to use.
The list of undocumented hminlib functions.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
