2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Use the Task Manager to load an XML file that defines tasks and their attributes.
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Modifies the xy plot axis limits so that the curves on the xy plot are fully visible.
Writes a plot to HyperMesh.
Writes the plot axis information to HyperMesh.
Writes the border of a plot to HyperMesh.
Writes the bounds of the plot to HyperMesh. Allows you to show specific sections of the plot.
Writes a curve that should be assigned to a plot to HyperMesh.
Writes the grid information of a plot to HyperMesh.
Writes the plot label information to HyperMesh.
Writes the axis label information to HyperMesh.
Writes the plot legend information to HyperMesh.
Writes the plot subtitle information to HyperMesh.
Writes the plot title information to HyperMesh.
The list of deprecated hminlib functions, and the new functions to use.
The list of undocumented hminlib functions.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
