2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Returns a flag which indicates if the markers will be displayed.
Returns a flag which indicates if measures will be displayed.
Sets the global display state for markers.
Sets the global display state for measures.
Use the Task Manager to load an XML file that defines tasks and their attributes.
