2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Adds the curves of the selected markers to the specified existing plot window.
Creates a new plot with all the curves of the selected markers on the specified plot window.
Previews all the curves of the selected markers on the specified plot window.
Use the Task Manager to load an XML file that defines tasks and their attributes.
