2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Adds the curves of the selected measures to the specified existing plot window of the specified plot type.
Creates a new plot with all the curves of the selected measures on the specified plot window of the specified plot type.
Previews all the curves of the selected measures on the specified plot window of the specified plot type.
Use the Task Manager to load an XML file that defines tasks and their attributes.
