2024
Result loading.
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Marks entities on the active model.
Open files.
Report commands.
Resets the legend for contour, vector, tensor, and iso based on the currently displayed parts.
Create and manage file sets for derived loadcases.
Create and manage iso plots.
Create and manage loadcases for derived loadcases.
Create and manage the contour plot.
Set the current simulation.
Makes a subcase current.
Create and manage tensor plots.
Create and manage vector plots.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
Use tracing commands to trace system, component, and node entities during animation.
View manipulation.
Perform actions on XY plot files.
Use the Task Manager to load an XML file that defines tasks and their attributes.
