2024
Modify entities in a selection set.
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Marks entities on the active model.
Open files.
Report commands.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Adds entities to a selection set.
Creates an empty selection set.
Deletes a selection set.
Creates a set with displayed entities.
Exports sets to a file.
Imports a set from a file.
Renames a selection set.
Removes entities from a selection set.
Define a coordinate system.
Tracking system commands.
Use tracing commands to trace system, component, and node entities during animation.
View manipulation.
Perform actions on XY plot files.
Use the Task Manager to load an XML file that defines tasks and their attributes.
sset entity argument ?argument? ?argument?
