2024
Perform actions on XY plot files.
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Marks entities on the active model.
Open files.
Report commands.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
Use tracing commands to trace system, component, and node entities during animation.
View manipulation.
Copy, create, cut, delete, edit, and paste an axis, either defined by a range or the marked entity.
Copy, create, cut, delete, edit, paste, and perform stackmath operations on curves, either defined by a range or the marked curve(s).
Copy, create, cut, delete, edit, and paste datum lines, either defined by a range or the marked entity.
Edit footer properties, either defined by a range or the marked entity.
Edit header properties, either defined by a range or the marked entity.
Edit legend properties, either defined by a range or the marked entity.
Load an xy file to plot.
Add, clear, create, delete and edit marks for a curve(s).
Copy, create, cut, delete, edit, and paste notes, either defined by a range or the marked entity.
Define the layout and appearance of the plot.
Edit plot attributes found in the Plot Browser and modify plot views.
Select a file set or subset.
Use the Task Manager to load an XML file that defines tasks and their attributes.
xy entity argument ?argument?
