2024
Mathematical functions and operators, including syntax, operators and specific information about each function.
Overview of functions and operators.
List of external functions.
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Use the Task Manager to load an XML file that defines tasks and their attributes.
Templex is a general purpose text and numeric processor which generates output text based on guidelines defined in a template.
The mathematical functions accept arguments of different data types.
The standard mathematical order of operations is followed when an expression is evaluated.
List of operators.
List of standard functions.
Creates a bar chart representation of selected data.
Applies the analog Bessel filter on the input signal.
Applies a digital Bessel filter on the input signal.
Filters data forward and backward using a second order Butterworth algorithm.
The 3ms criterion commonly used to measure potential for chest injury.
Calculates the cumulative duration for response values, given the X and Y input data vectors. The duration will be partitioned into 100 segments.
Performs 100 Hz finite impulse response filtering of a digitized time series.
Removes overlaps in curves.
The Head Injury Criterion commonly used to measure potential for head injury.
Modified Head Injury Criterion for use with the free-motion head form.
Creates a simplified histogram representation of selected data.
SAE J211/1 revision MAR95 filter with ISO 6487 compliant mirroring applied.
nee-thigh-hip injury function.
Signal processing tool that extracts equivalent constant amplitude fatigue cycles from a time series of load or strain data.
Calculate the Neck Injury Criteria.
Reduces the number of vector points from the test data without losing the damage, magnitude, and/or effect of the test data.
SAE J211/1 revision MAR95 compliant filter.
Four-pole Butterworth filter.
Channel Frequency Class filter.
Fir100 filter.
Low Pass Fourier filter.
SAE class filter.
Tchebychev class filter.
Signal processing tool that indicates how long the signal spends at a given magnitude.
Since the Nyquist frequency is half the sampling frequency, a higher sampling frequency will yield a spectrum in a wider frequency band.
Overview of Fast Fourier Transform, phenomena, windowing, Filtering Frequency Response, functions, blocking, and Hilbert Transform.
