2024
Mathematical functions and operators, including syntax, operators and specific information about each function.
Overview of functions and operators.
List of operators.
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Use the Task Manager to load an XML file that defines tasks and their attributes.
Templex is a general purpose text and numeric processor which generates output text based on guidelines defined in a template.
The mathematical functions accept arguments of different data types.
The standard mathematical order of operations is followed when an expression is evaluated.
Additive inverse.
Denotes a vector, matrix, string, or string array definition.
Addition operator.
Assignment operator.
Multiplication operator.
Subtraction operator.
Division operator.
Modulus operator.
Transpose operator.
Logical "not" operator.
Logical "and" operator.
Logical "or" operator.
"Less than" operator.
"Less than or equal to" operator.
"Greater than" operator.
"Greater than or equal to" operator.
Equality operator.
Inequality operator.
Increment operator.
Decrement operator.
Addition assignment operator.
Subtraction assignment operator.
Multiplication assignment operator.
Division assignment operator.
Range operator.
Index function.
Cross product operator.
Dot product operator.
List of standard functions.
List of external functions.
Overview of Fast Fourier Transform, phenomena, windowing, Filtering Frequency Response, functions, blocking, and Hilbert Transform.
