tblITableEditor GetFilledLowerRightCell
Returns bottom right cell name.
tblITableEditor_handle GetFilledLowerRightCell
Tcl Query
Returns the bottom right cell name with the column as name which contains a value.
The following cells are filled in a table:
The variable $filledBottomRightCell will be
“E9”.
set t [hw::GetT]
set activetableHandle [hwi GetActiveClientHandle ch$t]
set filledBottomRightCell [$activetableHandle GetFilledLowerRightCell]
