Returns information about the table cells which are not empty.
tblITableEditor_handleGetFilledTableDetailsFilled Table Size
Rows,Filled Table Size Columns,Filled Top Row
Index,Filled Bottom Row Index,Filled Left Column
Index,Filled Right Column Index,Filled Top Left
Cell,Filled Bottom Right Cell
Tcl Query
This command returns a list with the following information about the table cells which are
not empty.
Filled Table Size Rows
Number of rows between the top and bottom row, which contain cell values.
Number of columns between the left-most and right-most column, which contain cell
values.
Filled Top Row Index
Row index of the top row, which contain cell values.
Row index of the bottom row, which contain cell values.
Filled Left Column Index
Column index of the left-most row, which contain cell values.
Column index of the right-most row, which contain cell values.
Filled Top Left Cell
Top left cell name with the column as name.
Bottom right cell name with the column as name.
The following cells are filled in a table:Figure 1.
The variable $tableDetailList created with the code below will be { 5 4 5 9 2 5 B5
E9}.
set t [hw::GetT]
set activetableHandle [hwi GetActiveClientHandle ch$t]
set tableDetailsList [$activetableHandle GetFilledTableDetails]
