2024
View new features for Altair HyperWorks 2024.
Learn about sketching basics including the sketch plane, legend, constraints, context menu options, and construction geometry.
Create and assign variables to parameters when modeling.
Start a new sketch and select a sketch plane.
Project selected geometry onto the sketch plane as construction geometry.
Extract curves resulting from the intersection of the sketch plane with selected parts.
Sketch and edit a point, line, polyline, or line-arc.
Sketch and edit a rectangle.
Sketch and edit a parallelogram or a regular polygon.
Sketch and edit a circle.
Sketch and edit an ellipse or an elliptical arc.
Sketch and edit an arc.
Sketch and edit a spline.
Use the Dimension tool to define and/or constrain the dimensions of a sketch.
Translate or rotate sketch entities.
Trim or split a sketch curve.
Extend or shorten an entity of a sketch curve.
Round the corners of 2D sketch curves to create fillets with the same radius or different radii.
Offset or mirror a sketch curve.
Create a linear or circular pattern of sketch entities.
The Developer ribbon contains tools for automation and customization.
