2024
Discover OptiStruct functionality with interactive tutorials.
Tutorials using HyperMesh.
View new features for OptiStruct 2024.
OptiStruct is a proven, modern structural solver with comprehensive, accurate and scalable solutions for linear and nonlinear analyses across statics and dynamics, vibrations, acoustics, fatigue, heat transfer, and multiphysics disciplines.
Tutorials using Classic HyperMesh.
This tutorial uses OptiStruct's topology optimization functionality to generate a design for a cooling channel around a CPU. Darcy Flow analysis is used for the design.
This tutorial uses OptiStruct's topology optimization functionality to generate a design for a cooling channel of a Battery Pack and show how Darcy Flow analysis is used for the design.
Video tutorials using SimLab.
This manual provides detailed information regarding the features, functionality, and simulation methods available in OptiStruct.
This manual provides a detailed list and usage information regarding input entries, output entries, and parameters available in OptiStruct.
The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides you with examples of the real-world applications and capabilities of OptiStruct.
This manual presents solved verification models including NAFEMS problems.
This section provides quick responses to typical and frequently asked questions regarding OptiStruct.
