MOTNGE
Bulk Data Entry Defines a grid point motion through an expression.
| MOTNGE | SID | G1 | C1 | G2 | EID | D0 | V0 |
| MOTNGE | 3 | 345 | 3 | 4 |
| SID | Load set
identification number. (Integer > 0) |
| G1 | Grid point
| C1 | Component number (Integer 1 through 18). The component refers to the direction and type of motion of the grid point G1 in the Basic Coordinate System (not the Local Coordinate System). | |
| G2 | Grid point
identification number to define relative motion. (Integer > 0 or blank) |
| EID | Expression
identification number of the MBVAR entry that gives the
motion versus time. (Integer > 0) |
| D0 | Initial displacement if motion data is of type velocity or acceleration, ignored otherwise. | |
| V0 | Initial velocity if motion data type is acceleration, ignored otherwise. |
- The types and directions of motion for the
component numbers are given in the following table.
Component Number(s) Motion Type Direction(s) of Motion 1, 2, and 3 Displacement X, Y, Z 4, 5, and 6 Rotation X, Y, Z 7, 8, and 9 Translational Velocity X, Y, Z 10, 11, and 12 Angular Velocity X, Y, Z 13, 14, and 15 Translational Acceleration X, Y, Z 16, 17, and 18 Angular Acceleration X, Y, Z The component numbers and directions of motion are in the format: 1->X, 2->Y and 3->Z for Displacement and this format is followed for all the types in the table.
