TEMPP1
Bulk Data Entry Defines temperature field for shell elements (as a combination of reference plane temperature and linear thermal gradient through thickness) for determination of thermal loading, temperature-dependent material properties and stress recovery.
TEMPP1 SID EID1 TBAR TPRIME T1 T2
EID2 EID3 EID4 EID5 EID6 EID7 EID8 etc.
Alternate Format
EID2 THRU EIDi EIDj THRU EIDk
TEMPP1 10 5 100.0 5.0 75.0 125.0
17 20 21 30
6 THRU 21 25 THRU 54
SID LOAD set identification.
(Integer > 0)
EID# Element identification number of the element for which the TEMPP1 temperature is applied.
No default (Integer > 0)
TBAR Temperature at the shell reference plane.
Default = See Comment 10 (Real)
TPRIME Effective linear thermal gradient.
Default = 0.0 (Real)
T1 Temperature at lower surface of the shell elements.
Default = blank (Real)
T2 Temperature at upper surface of the shell elements.
  1. Temperature sets may be selected for use in a subcase by the TEMPERATURE, TEMPERATURE(MATERIAL), or TEMPERATURE(BOTH) Subcase Information Entries.
  2. Multiple TEMPP1 entries should not reference the same element ID (EID#). By extension, element ID's (EID#) should not be duplicated on the same TEMPP1 entry.
  3. TEMPP1 is only supported in Linear Static Analysis. It is currently not supported for optimization.
  4. If continuation entries are present, EID1 and subsequent elements specified on the continuation entry are assigned the temperature defined on this TEMPP1 entry.
  5. To apply thermal loading to any model, all elements must have a temperature field defined either directly on via TEMPP1 or indirectly as the average of the connected grid point temperature defined on the TEMP or TEMPD entries. Directly defined element temperatures (via TEMPP1) always take precedence over the average of grid point temperatures for the corresponding elements.
  6. The EIDi fields can reference CTRIA3, CQUAD4, CTRIA6, or CQUAD8 shell elements only.
  7. Currently, only a constant linear temperature gradient can be applied through the shell element thickness via the TPRIME field. If the temperature field in the physical structure is expected to vary non-linearly, then one option is to approximate an "effective gradient" for a homogeneous plate as:
    T P R I M E = 1 I ∫ − 1 2 1 2 z T ( z ) d z
    Where,
    I MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8 qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9 q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake aacaWGjbaaaa@39A5@
    Bending inertia
    z
    Distance from the neutral surface in the positive shell normal direction
    t MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8 qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9 q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake aacaWG0baaaa@39D0@
    Shell thickness
  8. Currently, only a single neutral plane temperature can be specified for a shell element via the TBAR field. If the temperature is expected to vary across the volume, then an average temperature for a homogeneous plate can be approximated as:
    T B A R = 1 V ∫ 0 V T ( V ) d V
    Where, V MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8 qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9 q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake aacaWGwbaaaa@39B2@ represents the volume of the shell element.
  9. The temperature value at any layer of the shell element is calculated as:
    T ( z ) = T B A R + z ( T P R I M E )
    Where, z is the distance from the neutral surface in the positive shell normal direction. If T1 and T2 are specified instead, then TBAR and TPRIME are calculated as:
    T B A R = T 1 + T 2 2 T P R I M E = T 2 − T 1 t
    Where, t MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8 qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9 q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake aacaWG0baaaa@39D0@ is the shell thickness.
  10. If the element material is temperature dependent, its properties are evaluated using the average temperature TBAR.
  11. For composite plate elements, temperature field given by TEMPP1 is applied to the homogenized composite elements.
  12. Loads based on temperature gradient through thickness is supported only if the MID2 field on the PSHELL entry references bending material properties.
  13. The temperature applied by TEMPP1 entry is directly used as temperature load for the corresponding element(s) only. Therefore, TEMPP1 loading does not contribute to the temperature load on any of the adjacent elements. For instance, if an adjacent element does not have a TEMPP1 load applied to it, then its loading is solely based on any TEMP load (if any) on its grid points. Otherwise, the TEMPD loading is used for such elements.
