/ANIM/SENSOR
Engine Keyword Write additional animation files (Animation Output File (A-File)) with a time frequency equal to Tfreq, the first file being written once sensor activated. (The activation of sensor will be defined in /SENSOR).
/ANIM/SENSOR
sens_ID Tfreq
Definition
sens_ID Sensor identifiers
Tfreq Time frequency
  1. The additional animation files are written in addition to classical animation files (/ANIM/DT) and in addition to animation files written by /ANIM/SENSOR.
  2. The additional animation files are written at each time a sensor of the list is activated. For more explanation, see option /SENSOR.
  3. If several /ANIM/SENSOR are defined in one Engine file, then only the last one will be take into account.
