*INITIAL_FOAM_REFERENCE_GEOMETRY
LS-DYNA Input Interface KeywordDefines the reference state for elements belonging to a part, using given nodal coordinates.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *INITIAL_FOAM_REFERENCE_GEOMETRY_{OPTION} | |||||||
| NSID | CID | ||||||
If OPTION = RAMP
| Nitrs |
Add a line for each node
| node_ID | X | Y | Z | ||||||
Definition
| OPTION |
| Nitrs | Number of steps from reference to
initial state. Default = 100 (Integer) |
| node_ID | Node
identifier. (Integer) |
| X | X coordinate. (Real) |
| Y | Y coordinate. (Real) |
| Z | Z coordinate. (Real) |
- This keyword maps to /XREF.
