*INITIAL_VELOCITY
LS-DYNA Input Interface KeywordDefines initial velocity of a node set.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *INITIAL_VELOCITY | |||||||
| set_ID | Exset_ID | IRIGID | CID | ||||
| VX | VY | VZ | VXR | VYR | VZR | ||
Read if Exset_ID > 0
| Blank | |||||||
Definition
| set_ID | Node set identifier.
(Integer) |
| Exset_ID | Node set identifier of nodes that
are exempted from the initial velocities (VX,
VY, VZ,
VXR, VYR,
VZR). (Integer) |
| IRIGID | Option to overwrite velocities
defined in *PART_INERTIA or
*CONSTRAINED_NODAL_RIGID_BODY_INERTIA.
(Integer) |
| CID | Coordinate system
identifier. (Integer) |
| VX, VY, VZ | Translational nodal velocity
components. (Real) |
| VXR, VYR, VZR | Rotational nodal velocity
- This keyword maps to /INIVEL.
