/OUTP
Engine Keyword Write ASCII formatted output files.
/OUTP/Keyword2/Keyword3/Keyword4
Definition
Keyword2 Refer to ASCII Output File (STY-File).
Keyword3 Refer to ASCII Output Files (STY-File)
Keyword4 Refer to ASCII Output Files (STY-File)
  1. Table of available functionalities for /OUTP:
    Keyword2 Keyword3 Keyword4
    DT
    VECT VEL, DIS, ACC, CONT, FINT, FEXT, FOPT, VROT, PCONT
    NODA DT, DMAS, DINER
    ELEM OFF, EPSP, ENER, VONM, HOUR, SLEN, USER1, USER2, USER3, USER4, USER5
    BRIC OFF, EPSP, ENER, DENS, TEMP, P, VONM, HOUR, USER1, USER2, USER3, USER4, USER5, STRES
    STRAI, STRES, USERS FULL
    SHEL OFF, EPSP, HOUR, ENER, THIC, VONM, USER1, USER2, USER3, USER4, USER5
    USRii FULL
    USERS FULL
    STRES, STRAI, EPSD0 MEMB, BEND, UPPER, LOWER, FULL
    TRUS OFF, EPSP
    SPRI OFF, FULL
    BEAM OFF, EPSP
    SPH OFF, EPSP, ENER, DENS, TEMP, P, VONM, STRES, SLEN, USER1, USER2, USER3, USER4, USER5
    STRES FULL
    Output for /OUTP:
    DT
    Nodal time step
    VEL
    For nodal translational
    DIS
    Displacements
    ACC
    Accelerations
    CONT
    Contact forces
    FINT
    Internal forces
    FEXT
    External forces
    FOPT
    Forces and moments for rigid bodies, rigid walls and sections
    VROT
    For nodal rotational velocities
    PCONT
    Contact pressure animation vector
    DMAS
    Mass variation (see time step control /DT/NODA/Keyword3/Iflag)
    DINER
    Output of added inertia per nodes
    OFF
    Output element status. In the sty file it displays:
    0
    Deleted element
    1
    Active element
    2
    Element switched to Small strain formulation.
    -1
    Element in standby (for example: belonging to a rigid body)
    EPSP
    Solid plastic strain
    ENER
    Solid internal energy
    VONM
    von Mises stress
    HOUR
    Hourglass energy
    SLEN
    Current smoothing length value
    Output user variables 1 through 5 in user law
    USRii
    Only one user variable number ii is output.
    Variable of user law on each integration points (ii =1 to 99 number of the variable).
    USERS
    Output all users variables in user material
    DENS
    Solid density
    TEMP
    Nodal temperature
    P
    Nodal pressure
    STRES
    Stress tensor
    STRAI
    Strain tensor
    FULL
    Strain or stress tensor
    MEMB
    Membrane
    BEND
    Bending
    UPPER
    Upper layer
    LOWER
    Lower layer
  2. The OUTP files are named according to Radioss Starter Input /IOFLAG.
