Interface TYPE2, also called tied interface is a nodal constraint to
rigidly connect a set of secondary nodes to a main surface. The secondary nodes forces and
moments are transferred to the main nodes, and then secondary nodes are positioned
kinematically according to the motion of the main nodes.
This interface ensures a full force and moment equilibrium.Figure 1. Interface TYPE2 - Tied
There are four formulations are available to describe this connection.
Default spotweld formulation
Optimized spotweld formulation
Formulation with failure
Penalty formulation
Default Spotweld Formulation
Spotflag=0Figure 2.
When the flag is set to 0, the spotflag formulation is a default formulation:
Based on element shape functions
Generate hourglass with under-integrated elements
Give a connection stiffness function of secondary node localization
Recommended with fully-integrated shells (main)
Recommended for connecting brick secondary nodes to brick main segments
(mesh transition without rotational freedom)
Optimized Spotweld Formulation
Spotflag=1Figure 3.
When the flag is set to 1, the spotflag formulation is an optimized formulation:
Based on element mean rigid motion
No hourglass problem
Constant connection stiffness
Recommended with under-integrated shells (main)
Recommended for connecting beam, spring, and shell secondary nodes to brick
main segments
Formulation with Failure
Spotflag=20, 21 and 22
Using these options, these two failure criteria can be defined:
Rupt= 0 (independent rupture parameters):
Failure when Max_N_Dist or
Max_T_Dist are reached (default)
Rupt= 1 (coupled rupture parameters):
Failure when
During the computation, a normal stress, shear stress, normal displacement and tangential displacement are computed and compared to the maximum values defined in the interface. As soon as the maximum criteria have been reached, the normal stress and shear stress will be set to 0.
Penalty Formulation
Spotflag=25
The main goal for interface TYPE2 using penalty method is to tie secondary node to main segment
without any kinematic constraints. Using the penalty method may avoid
