Engine Subroutine RUSERnn for Spring Elements
This subroutine calculates the internal forces and moment versus the velocity, old forces, moments, and user’s variables and parameters.
Arguments
C--------------------------------------------------------------------------
SUBROUTINE RUSERnn(NEL ,IOUT ,IPROP ,UVAR ,NUVAR ,
2 FX ,FY ,FZ ,XMOM ,YMOM ,
3 ZMOM ,E ,OFF ,STIFM ,STIFR ,
4 VISCM ,VISCR ,MASS ,XINER ,DT ,
5 XL ,VX ,RY1 ,RZ1 ,RX ,
6 RY2 ,RZ2 ,FR_WAVE)
Definition
| Argument | Format | Description |
| NEL | Integer read only scalar | Number of elements per group. In Radioss Engine subroutines, the element data are treated by groups for vectorization. This argument is machine-dependent and set by Radioss. |
| IOUT | Integer read only scalar | Output file unit (ROOTL00). |
| IPROP | Integer read only scalar | Property number. |
| UVAR | Float array read write | Array of size NEL*NUVAR containing user element variables. |
| NUVAR | Integer read only scalar | Number of user element variables. |
| FX | Float array read write | Array of size NEL containing an internal
local X force as input and a new force as output. Nodal X forces at nodes 1 and 2 in a local frame are defined as FX1 = FX and FX2 = -FX. |
| FY | Float array read write | Array of size NEL containing an internal
local Y force as input and a new force as output. Nodal X forces at nodes 1 and 2 in a local frame are defined as FY1 = FY and FY2 = -FY. |
| FZ | Float array read write | Array of size NEL containing an internal
local Z force as input and a new force as output. Nodal X forces at nodes 1 and 2 in a local frame are defined as FZ1 = FZ and FZ2 = -FZ. |
| XMOM | Float array read write | Array of size NEL containing an old
internal local X moment as input and a new moment as
output. Nodal X moments at nodes 1 and 2 in a local frame are defined as MX1 = MX and MX2 = -MX. |
| YMOM | Float array read write | Array of size NEL containing an old
internal local Y moment as input and a new moment as
output. Nodal Y moments at nodes 1 and 2 in a local frame are defined as MY1 = MY – 1/2*XL*FZ and MY2 = -MY – 1/2*XL*FZ. |
| ZMOM | Float array read write | Array of size NEL containing an old
internal local Z moment as input and a new moment as
output. Nodal Z moments at nodes 1 and 2 in a local frame are defined as MZ1 = MZ + 1/2*XL*FZ and MZ2 = -MZ – 1/2*XL*FZ. |
| EINT | Float array read only | Array of size NEL containing internal energy. |
| OFF | Float array read write | Array of size NEL containing deleted
element flags.
| STIFM | Float array write only | Array of size NEL containing element translational stiffness in time step computation. |
| STIFR | Float array write only | Array of size NEL containing element rotational stiffness in time step computation. |
| VISCM | Float array write only | Array of size NEL containing element translational viscosity in time step computation. |
| VISCR | Float array write only | Array of size NEL containing element rotational viscosity in time step computation. |
| MASS | Flat array write only | Array of size NEL containing element mass in time step computation. |
| XINER | Float array write only | Array of size NEL containing element spherical inertia. |
| DT | Float read only | Current time step |
| XL | Float array read only | Array of size NEL containing element length |
| VX | Float array read only | Array of size NEL containing X
velocity. Nodal velocities at nodes 1 and 2 in a local frame are defined as VX1 = -VX/2 and VX2 = VX/2. |
| RY1 | Float array read only | Array of size NEL containing Y rotational velocity at node 1. |
| RZ1 | Float array read only | Array of size NEL containing Z rotational velocity at node 1. |
| RX | Float array read only | Array of size NEL containing torsional
velocity. Nodal torsional velocities at nodes 1 and 2 in a local frame are defined as RX1 = -RX/2 and RX2 = RX/2. |
| RY2 | Float array read only | Array of size NEL containing Y rotational velocity at node 2. |
| RZ2 | Float array read only | Array of size NEL containing Z rotational velocity at node 2. |
| FR_WAVE | Float array read only | Array of size NEL not yet used. |
