Measure Distance
Find the distance between two points on the model.
- In the main window toolbar, click the (Measurements) icon.
- In the dialog, click the Distance tab.
In the modeling window, pick two points on the model
surface.
The dialog will display the distance between the two points.Note: The points do not have to lie on the same face; the distance is measured directly through 3D space, not along the model surface.
- Click Close.
