Measure Using Ray Probe
Launch a ray through the model and measure lengths of segments where the ray intersects the model surface.
- In the main window toolbar, click the (Measurements) icon.
- In the dialog, click the Ray probe tab.
- Optional: Orient the model so the desired ray direction is normal to the screen.
- Specify the Ray direction.
In the modeling window, pick a point on the
model.
The dialog box displays the list of segments where the ray intersects the model surface, as well as their lengths.
- Optional: Select two segments from the list to show the distance between the segments.
- Click Close.
