A faulty or incomplete environment definition can cause problems with running jobs.
Example: A job succeeds when executed directly from the command line but fails when
executed by the taskers.
The utility
taskerdebug
can be used to debug the environments used by the
taskerdebug. This utility
prints all environment variables, aliases and equivalences into the file that is
given as its first argument. In the following example, the environment named
BASE
is debugged, and
base.out is the
output file:
% ves BASE
% vov taskerdebug base.out
The command can now be retraced on selected taskers and check the
file base.out for clues about the problem with the environment.
If necessary, use the resource mechanism to direct the job to the desired tasker.
Note: The taskerdebug
command is implemented as a csh script on UNIX, and a .bat script for Windows. The
command machinfo can also be used, which is implemented in Tcl.
Implemented in Tcl allows using this command in either UNIX or Windows. This may be preferred, as the machinfo output
provides more information than the command taskerdebug on Windows.
Environment Checking
To verify if an environment is good, use
vovenvcheck, which checks
that all variables set in the
start.* file are properly unset
in the
end.* file.
Example:
% vovenvcheck env_name
