To save time while switching environments,
taskers cache up to
eight environments, which makes switching instantaneous. The cached environments can
be refreshed either through the GUI by clicking , or by
entering:
% vovtaskermgr refresh
Refreshing is necessary if you modify an environment after the
taskers have cached it. Restarting the
taskers
achieves the same result at a slightly higher cost.
CAUTION:
On Windows
NT, refresh does not work. You must restart the taskers
instead.
