Define Jobclasses
This VOV_JOB_DESC data structure is an associative array that describes the characteristics of a job. The array has a number of slots that hold the values describing the job. The following table shows the array slot fields.
Field in Array
autokill
Set the autokill flag (option -kill)
check,directory
Set it to 0 to disable checking of canonicalization of current directory (option -D)
env
Environment of the job (option -e). Set this to "" or to DEFAULT to force the use of an environment snapshot.
force
Force the job to be rescheduled (option -F)
group
Group the job belongs to (option -g)
group,final
Group the job belongs to including the user subgroup (option -G)
inputs
List of input files (dependencies) (option -i)
interactive,flag
Used for interactive jobs, with values tty_remote (option -Ir) or tty_local (option -Il)
interactive, useXdisplay
Set if the job requires an X display (option -Ix)
logfile
Name of the log file (option -l)
mailuser
Specification of who gets the e-mail notification (option -M)
osgroup
The UNIX group this job. This field is read-only and cannot be changed (see also user)
outputs
List of output files (option -o)
preemptable
A suggestion to determine if the job is preemptable
priority, default
Default priority (NOT USED)
priority, exec
Execution priority
priority, sched
Scheduling priority
proplist
Properties to be added to the job (option -P)
resources
The resources of the job (option -r)
rundir
The running directory for the job (normally)
schedule, date
NOT SUPPORTED YET
setName
The set to which the job belongs (option -set)
user
The user for this job. This field is read-only and cannot be changed (see also osgroup)
wait
Boolean: set it to 1 to wait for the job to complete (option -w)
wait,options
When waiting, these options are passed to the nc wait command. For example, set it to -l to view the log file
wrapper
Wrapper used for the job (option -wrapper)
xdur
Expected duration of the job (option -X)
The following is an example of the populated VOV_JOB_DESC array.
VOV_JOB_DESC(autoforget)              = 0
VOV_JOB_DESC(autokill)                = 1
VOV_JOB_DESC(check,directory)         = 1
VOV_JOB_DESC(env)                     = BASE+RTSIM
VOV_JOB_DESC(force)                   = 0
VOV_JOB_DESC(group)                   = users
VOV_JOB_DESC(inputs)                  =
VOV_JOB_DESC(interactive,flag)        = none
VOV_JOB_DESC(interactive,useXdisplay) = 0
VOV_JOB_DESC(logfile)                 = vnc_logs/20050920/131409.25563
VOV_JOB_DESC(mailuser)                =
VOV_JOB_DESC(osgroup)                 = guests
VOV_JOB_DESC(outputs)                 =
VOV_JOB_DESC(priority,default)        = 4
VOV_JOB_DESC(priority,exec)           = 4
VOV_JOB_DESC(priority,sched)          = 8
VOV_JOB_DESC(proplist)                =
VOV_JOB_DESC(resources)               = linux
VOV_JOB_DESC(rundir)                  = .
VOV_JOB_DESC(schedule,date)           = 0
VOV_JOB_DESC(setName)                 =
VOV_JOB_DESC(user)                    = mary
VOV_JOB_DESC(wait)                    = 0
VOV_JOB_DESC(wait,options)            =
VOV_JOB_DESC(wrapper)                 = vw
VOV_JOB_DESC(xdur)                    = 30
