Define a Default Jobclass
When defined, a default jobclass is evaluated for each job as it is submitted before any other nc run options are parsed. The default jobclass should be simple and limited to actions such as supplying basic values for RAM/ and CORES/.
When a default jobclass is in effect, the values it establishes may be changed if a jobclass is later named by the -C option of the nc run command.
- Via the Jobclass page web page.
- Setting a property from the CLI.
normal
is set as the default jobclass.% nc cmd vovprop SET -text 1 "NC_DEFAULT_JOBCLASS" "normal"
% nc cmd vovprop GET 1 NC_DEFAULT_JOBCLASS
Jobclass Definitions Examples
# This is file short.tcl
set classDescription "Jobs taking less than 30s"
set classEditable true; # Allow editing via web UI
set VOV_JOB_DESC(xdur) 30
set VOV_JOB_DESC(autokill) 1
set VOV_JOB_DESC(priority,sched) 8
set VOV_JOB_DESC(env) "BASE+D(VOV_LIMIT_cputime=30)"
proc initJobClass {} {}
# This is file interactive.tcl
set classDescription "Interactive Jobs"
set classEditable false; # Disallow editing via web UI
set VOV_JOB_DESC(resources) ""
# Make the environment unique for each interactive job,
# so that multiple submissions of the same command in the same
# directory will result in multiple jobs
set VOV_JOB_DESC(env) "BASE+D(uniquify=[clock seconds])"
set VOV_JOB_DESC(priority,sched) 9
set VOV_JOB_DESC(interactive,useXdisplay) 1
# We want Crtl-C and similar commands to be handled by the remote host.
set VOV_JOB_DESC(interactive,flag) "tty_remote"
# We do not want any wrapper for interactive jobs,
# to allow stdout and stdin to go directly to the TTY.
set VOV_JOB_DESC(wrapper) ""
