vtk_flexlm_monitor Procedures
Your Accelerator setup will get license in-use info from your Monitor or Monitor-basic setup via HTTP on Monitor's /raw interface. The default resources.tcl file for Accelerator includes the vtk_flexlm_monitor_all procedure. This converts every feature monitored by Monitor into an Accelerator resource. If the resource name is specified, then this name is the actual resource name used. If the resource name is not specified, the name defaults to License:<feature>.
If you do not wish to have a large number of resources, you can comment out the above and put calls to the vtk_flexlm_monitor procedure in your resources.tcl file to specify which FlexNet Publisher features Accelerator should monitor.
