Wait for Jobs
nc
run
returns immediately after you submit a job. This allows you to
submit multiple jobs at once. There could be times when you want to run jobs in
sequence, in which case option -w
is very useful. With this option,
nc run
waits for the job(s) to finish ( Done or Failed ).
% nc run -w sleep 10
Resources= linux
Env = D(VOV_ENV_SOURCE=vnc_logs/envdexin36362.env)
Command = vw vwrap sleep 10
Logfile = vnc_logs/20021231/111314.21781
JobId = 04211346
vnc: message: Scheduled jobs: 1 Total estimated time: 0s
Wait for Jobs and Show Log File of the last job: -wl
nc run
waits for the job(s) and shows the log file
of the last
job.% nc run -wl date
Resources= linux
Command = vw vwrap date
Logfile = vnc_logs/20021231/111530.21819
JobId = 04211392
<<<STARTING ON rhino>>>
Tue Dec 31 11:15:31 PST 2002
<<<END OF LOG>>>
<<<EXIT STATUS 0>>>
Please only use -wl
for jobs where you are actively monitoring the
output. Such jobs listen to the vovservers event stream and are called 'notify
clients'. They are more resource-intensive than plain batch jobs.
Wait for Jobs Using nc wait
You can also wait for jobs using the command nc wait. We will cover that in next tutorial "Job Control".
