Connect to a Project via the Command Line
To connect to a VOV project, get a list of the projects with vovproject list, and then enable the selected project.
Example:
% vovproject list
% vovproject enable mytestmac05 mytest@mac33 DEFAULT documentation/html >
After connecting to a VOV project, a different prompt may appear, which indicates for the current project and the current environment.
The project is now set up for interaction. Example:
% vsi
% vovconsole &
% vsr -all
