Troubleshooting: Cannot Enable Project
% vovproject enable MYPROJECT
and you receive an error
similar to
this:vovproject 06/16/09 10:53:47: FATAL ERROR: Cannot find project 'MYPROJECT for user 'john'
There may be other projects that are in conflict with the current project, perhaps running on the same machine and have the same project name, but a different port number.
% vovproject list -a
- Is your project listed? Is it running?
- Are there multiple projects with the same name?
- Is there a file similar to
MYPROJECT@SOMEHOST
? - Are there more files like that?
% source $VOVDIR/etc/vovrc.csh ## To make sure the alias is loaded.
% ves path/to/mytestproject.swd/setup.tcl
