Thin Clients
A thin client (VOV protocol) runs on a machine that does not have access to the SWD directory of the vovserver.
Connect a Thin Client
Such a client cannot read the configuration files for the project, such as the equiv.tcl file that defines logical filesystem names, or the setup.tcl file that defines necessary server environment variables.
An example of a thin client is the vovinfo
binary, a stripped-down
version of vovsh
that is used for host monitoring in Monitor.
Environment Variables
setenv VOVEQUIV_CACHE_FILE vovcache
setenv VOV_SWD_KEY none
This setting of VOVEQUIV_CACHE_FILE disables checking the equiv.tcl file. The client gets
equivalences from the server cache, if available, via the VOV protocol RPC. Setting
VOV_SWD_KEY to
none
causes the client to avoid accessing the server working
directory.
