Analysis Menu
Transient SSN Analysis: Upon selecting this menu, the Simultaneous Switching Noise Analysis dialog opens.
SYZ Parameter Viewer: You can see pre-saved PDN analysis result.
- From the menu bar, select to view editable, versatile control parameters which influence the simulation/analysis result.
Start DC IR Drop analysis.
- From the menu bar, select .
- Select the required power net.
- Click Run Analysis.
Start AC PDN analysis.
- Select the required test case to simulate.
From the menu bar, select to add VRM Port to the existing AC PDN analysis result.
By default, only the ports of load pins are included in the AC PDN analysis result.
- From the menu bar, select to open the Simultaneous Switching Noise Analysis dialog.
- From the menu bar, select to view pre-saved PDN analysis results.
