Export DXF/DWG
Export the current sketch as a .dxf or .dwg file.
Double-click a sketch entity to enter sketch edit mode.
Tip: You can also right-click a sketch and choose Edit or double-click a sketch in the Model Browser or History Browser to enter sketch edit mode.
On the Sketching ribbon, select the Export DXF/DWG
icon.
- In the dialog box, select a folder, name your file, choose between .dxf or .dwg, and then click Save.
