LS-DYNA Interface
New Features
- Support for LS-DYNA F14.1 and R15.0 Profiles
- Support for LS-DYNA F14.1 and R15.0 profiles has been added.
- New Mass Balance Workflow
- The Mass Balance tool can be used to automatically distribute masses on nodes or properties, to match user-defined target mass and CoG of selected properties.
Enhancements
- Find Attached Tool
- *CONSTRAINED_EXTRA_NODES_{OPTION} and *CONSTRAINED_RIGID_BODIES are considered in find attached tool via check boxes in the tool options.
- Model Checker
- A new “*CONSTRAINED_INTERPOLATION with weight factors equal to 0.0” warning has been added.
- Keywords Support
- Support of *CONTROL_FORMING_ONESTEP_{OPTION} has been added.
Resolved Issues
- Performing nodes equivalencing workflow will now maintain ELEMENT_MASS defined on equivalenced nodes.
- Default weighting factors in *CONSTRAINED_INTERPOLATION are now defined equal to TWGHTX value and not more equal to 0.0.
- The review of *CONTACT_AUTOMATIC_SINGLE_SURFACE with SSID=0 has been fixed.
- *CONTACT_AUTOMATIC_SINGLE_SURFACE with SSID=0 is no longer found as empty in check tools.
- *SET with option COLLECT is now correctly combined when include files are imported successively in HyperMesh.
- The option OFFSET in *ELEMENT_BEAM is now accessible from the element Entity Editor.
- The model import issue when encryption block is defined after *MAT_SEATBELT has been fixed.
- The import of *SECTION_SOLID_EFG when attributes IEBT=0 or IDIM=0 or IBR=0 has been fixed.
- NUM attribute in *MAT_154 is now supported as an integer.
