PAM-CRASH Interface
New Features
- New Mass Balance Workflow
- The Mass Balance tool can be used to automatically distribute masses on nodes or properties, to match user-defined target mass and CoG of selected properties.
Enhancements
- SEG and EDG element entities are migrated to the SET_SEGMENT entity.
- The find attached workflow has been enhanced by adding Include Tied contact and Include link elements. Link elements include LLINK, SLINK, and PLINK elements.
- The attribute IEEDGPLK projection algorithm has been added for the PLINK keyword.
- The Organize Xlinks script has been removed from the Organize ribbon. The Connector workflow should be used instead.
Resolved Issues
- The Material 101 export issue for exporting Linear isotropic formulation and Generalized orthotropic formulation parameters together has been resolved. The Formulation method selector has been added.
