Domain
In the domain section, the global definitions for the simulation are set, such as the number of dimensions and the numerical reference parameters.
Commands
domain
     ndim                              3
     min_domain                        "0.0 0.0 0.0"
     max_domain                        "1.0 3.0 0.0"
     BC_min                            "OUTLET PERIODIC SIMPLEOUTLET"
     BC_max                            "OUTLET PERIODIC SIMPLEOUTLET"
     outlet_vel                        "0.05 0.0 0.0"
     outlet_bodyforce_on               true
     ref_rho                           1000.
     ref_length                        0.1
     ref_vel                           1.0
     ref_curv                          1.0
     ref_visc                          0.001
     bodyforce                         "0.0 0.0 -9.81"
     bodyforcefile                     bodyforcefile.txt
     bodyforcefile_latch               false
     bodyframe_active                  false
     bodyframe_states                  "1 2 3 4 5 6 7 8 9"
     bodyframe_statesfile              bodyframestatesfile.txt
     bodyframe_statesfilelatch         false
     bodyframe_origin                  "0 0 0"
     bodyframe_terms                   "0 0 0 0"
     bodyframe_fallbackterms           "0 0 0 0"
     t_damp_bodyforce_start            0.0
     t_damp_bodyforce_end              0.1
     inputfile                         initialparticlepositions.prtl
     inputfileReadMode                 INPTFL_AUTO
     inputfile_type                    INPTFL_TAUTO
     inputfile_factor                  1.0
}Definitions
| Command | Contents | SI Unit Example |
| ndim | The dimensionality of the problem. 1 Options
| min_domain | Minimum bounds of the computational box (vector defining a point
                                    location). Note: If both min_domain and
                                        max_domain are not specified in the
                                    configuration file, the variables will be determined by the code
                                    automatically. 1 | |
| max_domain | Maximum bounds of the computational box (vector defining a point
| BC_min | Boundary condition at the minimum boundary. For an illustration
                                of domain boundaries, refer to Comment 2. Options
 Related Commands
| BC_max | Boundary condition at the maximum boundary. For an illustration
 Related Commands
| outlet_vel | Specifies the velocity of the OUTLET boundary. Note:
| outlet_bodyforce_on | If this flag is switched on, the outlet particles will experience
                                the prescribed body force. This is useful in cases where the outlet
                                plane is perpendicular to the body force (gravity) direction. In
                                these case, the zero gradient velocity at the outlet no longer applies. Options
| ref_rho | Reference density. This should be the lowest fluid density in the
                                    domain. Important: All reference values have been
                                    automated. They can be set manually, as is recommended.
                                    Depending on the case definition, the code will automatically
                                    pick up the reference values, provided that the
                                        max_dist command is defined in the motion
                                    definition. Note: For density, the lowest fluid density is
                                    picked up as the reference. Default = If not specified, the code will automatically detect it. | |
| ref_length | Reference length. A typical length scale defining the relevant
                                    physics. Note: It is recommended that you specify this reference
                                    value, as it can be difficult for the code to identify the
                                    correct value in certain cases. For length, the code will
                                    analyze the size of the domain in the direction of the body
                                    force applied and choose that length as the reference length.
                                    This means that if variable body force is being used, the
                                    reference length is specified manually. Examples:
 Default = The code will automatically try to find a relevant length for a hydrostatic problem. | |
| ref_vel | Reference velocity. Should be the highest expected velocity in
                                the domain. Note: For velocity, if there is defined motion in the
                                    configuration file, the code will automatically calculate
                                    maximal velocity of the motion, multiply it by a
                                        ref_vel_factor (the default value is 1.5)
                                    for conservative purposes, and set that value as the reference
                                    velocity. If there is no motion defined, or if the motion is
                                    rigid body or position file, the reference velocity must be
                                    defined manually. Default = If the motion is defined in the .cfg file, the code will automatically calculate the maximum velocity and multiply it by the ref_vel_factor value in order to assure stable running of the simulation. | |
| ref_curv | Reference curvature (needed only if
                                    surften_model is set to
                                    ADAMI or SINGLE_PHASE). Should
                                be the curvature of the smallest droplet that needs to be resolved
                                (1/radius of the droplet). Note: For reference curvature, the default
                                    curvature is set as 1/(5*dx). In order to
                                    resolve droplets accurately, there needs to be a droplet radius
                                    of at least five particles. Default = If not specified, the value is set to 1/(5*dx) Related Commands
| ref_visc | Reference viscosity (needed only if
                                    viscTempCoupling is set to true). Should be
                                the highest expected viscosity in the domain. Related Commands
| bodyforce | Global acceleration field in inertial frame. Usually
                                    gravity. Note: Body force vector must be specified (if using
                                    variable body force file, the latter
                                        bodyforcefile command will overwrite
                                    it). | [m/s^2] |
| bodyforcefile | File bodyforcefile.txt contains the body force
                                vector as a function of time. Note: This is
                                    simultaneously a switch for the code. If this command is
                                    present, it will use the specified input file and ignore the
                                    previous bodyforce input. Related
                                        Commands
| bodyforcefile_latch | Set to true to use the nearest value in the
                                    bodyforcefile.txt file when current
                                simulation time is out of the time range defined in
                                    bodyforcefile.txt Default: false | |
| bodyframe_active | Set to true to activate simulation in body frame (moving
                                reference frame). When active, bodyforce keyword
                                can be used to specify the inertial frame states, for example
                                gravity. Use of bodyforcefile in conjunction with
                                body frame is not possible. Default: false | |
| bodyframe_states | States of the body frame with respect to inertial frame for three
                                directions (linear acceleration, angular acceleration and angular
                                velocity) in the order of "acc_x acc_y acc_z angacc_x
                                    angacc_y angacc_z angvel_x angvel_y angvel_z". The
                                values are ramped from zero between
                                    t_damp_bodyforce_start and
                                    t_damp_bodyforce_end. Default: "0 0 0 0 0 0 0 0 0" | [m/s^2 m/s^2 m/s^2 rad/s^2 rad/s^2 rad/s^2 rad/s rad/s rad/s] |
| bodyframe_statesfile | File bodyframestatesfile.txt contains the body
                                frame states with respect to inertial frame as a function of time.
                                The file has 10 columns (time, linear acceleration vector
                                components, angular acceleration vector components, angular velocity
                                vector components) with the order "time acc_x acc_y acc_z angacc_x
                                angacc_y angacc_z angvel_x angvel_y angvel_z" . When present,
                                    bodyframe_states,
                                    t_damp_bodyforce_end are ignored.
                                    Bodyforce keyword can be used to specify the
                                inertial frame states, for example gravity, with respect to inertial
                                frame as a function of time. Default: empty | [s m/s^2 m/s^2 m/s^2 rad/s^2 rad/s^2 rad/s^2 rad/s rad/s rad/s] |
| bodyframe_statesfilelatch | Set to true to use the nearest value in the
                                    bodyframestatesfile.txt file when current
                                simulation time is out of the time range defined in body frame
                                states filebodyframestatesfile.txt. Default: false. | |
| bodyframe_origin | Initial origin of the body frame (moving reference frame) with
                                respect to inertial frame in [m]. Default: "0 0 0" | [m] |
| bodyframe_terms | Activation of fictitious terms with the order of "linear Euler
                                centrifugal Coriolis". Set an element to a positive number to
                                activate the relevant fictitious term in body frame (moving
                                reference frame). Default: "0 0 0 0" | |
| bodyframe_fallbackterms | Inclusion of fictitious terms with the order of "linear Euler
                                centrifugal Coriolis" in fallback reference length, speed of sound
                                and time step size. Set an element to a positive number to activate
                                the relevant fictitious term in body frame (moving reference
                                    frame). Default: same as bodyframe_terms | |
| t_damp_bodyforce_start | Start time of the body force ramp-up process. Before this time, the body force is zero. Starting from this time, a body force is gradually increased. Note: Ramping up to the given
                                    value is defined with t_damp_bodyforce_start
                                    and t_damp_bodyforce_end
                                    commands. Default = 0 | |
| t_damp_bodyforce_end | End time of the body force ramp-up process.This time must not be smaller than t_damp_bodyforce_start. Within the time interval between t_damp_bodyforce_start and t_damp_bodyforce_end the body force is ramped up to reach the full body force at t_damp_bodyforce_end. At later times the full body force is applied. Default = 0 | |
| inputfile | This file is the geometry input file (textfile) and needs to be present in the folder where the simulation is launched together with the config file. | |
| inputfile_factor | This factor can be used to scale the input file
                                        content. Note: nanoFluidX uses
                                    SI-units. Therefore, this factor is useful if a model is created
                                    in SimLab in millimeter-units and
                                    needs to be converted to meters while reading in. Example:
 Default = 1.0 | |
| inputfileReadMode | Describes the data format that is to be read in. Options
| inputfile_type | Data file type of input particle file. Options
 Note: Depending on the case,
                                    ASCII type particle files have a size of around 75 bytes per
                                    particle for the current format. For binary type particle files,
                                    this reduces to 28 bytes per particle, which translates to
                                    binary particle file sizes between half and one third of
                                    equivalent ASCII type particle file sizes. |
- If both min_domain and max_domain are not specified in the configuration file, the code will automatically detect the minimum and maximum dimensions of the case and create a bounding box automatically. This is useful when operating with closed geometry, such as a gearbox. To simulate a sloshing/splashing case where the fluid is not constrained within solid walls, or if there are periodic or inlet boundary conditions associated with the domain, it is necessary to manually prescribe the size of the domain (bounding box). [ndim, min_domain, max_domain]
- Each of the six bounding planes is
                        marked in a separate color, with the colored arrow showing the surface
                        normal of the boundary. The direction of these surface normals in the sketch
                        has no influence on the code execution, they are provided to help visualize
                        the domain. The two red dots at the opposite corners of the domain are
                        minimum and maximum extent of the domain. [BC_min, BC_max]Figure 1. Sketch of nanoFluidX domain boundaries
