Phases
In the phases section the material parameters are defined for different SPH components.
The name of the phases as given/used in SimLab is not important, only the material ID in SimLab that relates to the phase number as defined here. The first phase definition in the configuration file defines the properties of the SPH particles with the material ID “1”, the second group for the material ID “2”, and so on.
For more information, refer to Solver Features in the Theory Manual.
Commands
phases
    phase
         name                       Water
         type                       FLUID
         rho_0                      1000.
         dyn_visc                   1.e-3
         surf_ten                   0.1
         temp_0                     0.
         heat_cond                  0.
         heat_cap                   0.
         evolve_temp                false
         rho_compr                  0.01
         pc_factor                  1.0
         print_info                 false
         print_phase                true
         cs                         100
         rm_rho_theta               1.1
         init_vel                   “0.0 0.0 0.0”
    phase
         name                       Housing
         type                       WALL
         heat_cond                  0.0
         heat_cap                   0.0
         temp_0                     0.0
         evolve_temp                false
         noSlip                     true
         print_info                 true
         print_phase                true
         adhesionCoeff              0.01
         contact_angle              90.0
         fluidContactPhase          1
         makesubphase               true
    phase
         name                        Something_moving
         type                        MOVINGWALL
         rho_0                       1.0
         heat_cond                   0.0
         heat_cap                    0.0
         temp_0                      0.0
         evolve_temp                 false
         noSlip                      true
         print_info                  true
         print_phase                 true
         adhesionCoeff               0.01
         contact_angle               90.0
         fluidContactPhase           1
         makesubphase                true
}Definitions
| Command | Contents | SI Unit Example |
| name | The name of this phase. Note: This does not need to match the
                                        component name in SimLab. Options
| type | The type of the phase defines the physical behavior. Attention: This property is mandatory. Options
| rho_0 | The reference density of this phase. This is the initial
                                    density of all particles of this phase. Warning: In
                                        case that the body is defined as rigid
                                            (fluidCoupledMotion), this value is
                                        overridden by a density which is calculated based on the
                                        specified mass of the body (body_mass)
                                        and the total number of particles representing the phase in
                                        question. Default = 1.0 | |
| dyn_visc | The dynamic viscosity of this phase in [kg / (m s), Pa
                                        s]. Warning: If
                                            viscTempCoupling
                                        (temperature-viscosity coupling) is set to true, this value
                                        will be ignored since it is specifically defined by
                                        temperature-viscosity models which determine the viscosity
                                        of the fluid. Note: For more information, refer to
                                            Viscosity Models. Default = 0.0 | |
| heat_cap | The specific heat capacity at constant pressure
                                        (Cp) of this phase. Related Commands
 Default = 0.0 | [J/kg/K] |
| heat_cond | The heat conductivity of this phase. Related Commands
 Default = 0.0 | [W/m/K] |
| evolve_temp | This flag can be used to set the temperature of a phase
                                    constant, or to allow it to evolve using the energy equation. Options
 Related Commands
 Default = false | |
| noSlip | Switch to enable the WALL or
                                        MOVINGWALL to become a slip or no-slip
                                    boundary condition. Options
 Default = true | |
| temp_0 | The initial temperature of a phase in Kelvin [K]. Related Commands
 Default = 273.15 | |
| surf_ten | The surface tension coefficient [N/m]. Note:
 Related Commands
 Default = 0.0 | |
| rho_compr | The compressibility of the fluid. Note: Following the weakly
                                        compressible approach, the admissible density variation is 1
                                        percent. For example, rho_compr =
                                        0.01. CAUTION: Changing this value without
                                        an advanced understanding could have undesired
                                        consequences. Default = 0.01 | |
| pc_factor | Background correction pressure associated with the transport
                                    velocity formulation. It can have an arbitrary value, however it
                                    is generally recommended to keep it on the same order of
                                    magnitude of the
                                        p0 (base
                                        pressure). Related Commands
 Default = 1.0 | |
| print_info | If this Boolean flag is set to true, an additional file is
                                    written during the simulation with the filename
                                        name_info.txt
                                        (name is the phase
                                        name as defined earlier). The content is
                                    written every #N steps (see dt_phaseinfo) and
                                    contains information on for example the forces, torques, kinetic
                                    energy and center-of-mass of this phase. Options
 Default = false | |
| print_phase | This Boolean flag switches the output of this phase on or
                                    off. This switch is useful to limit the amount of output since
                                    wall particles, for example, do not change their position in
                                    time and might not be necessary in the output. Options
 Default = false | |
| cs | Specify the speed of sound in the FLUID
                                    phases (individually). Note: By default, this parameter is left
                                        out of the phase definition in which case the code will use
                                        the automatically calculated speed of sound based on the
                                            ref_vel and
                                            rho_compr. Speed of sound can have a
                                        profound influence on the overall behavior of the simulation
                                        and is generally considered an advanced
                                        parameter. CAUTION: Defining this value
                                        without an advanced understanding could have undesired
                                        consequences. | |
| rm_rho_theta | Scaling parameter designed to enable local particle density
                                    reinitialization once the threshold of
                                        rho_0*rm_rho_theta is
                                        exceeded. Restriction: This parameter is only
                                        available and meaningful when Riemann scheme is
                                        used. Tip: Suggested best practices
                                        maintain the stability of the Riemann formulation in
                                        multiphase simulations.
| rm_beta | Numerical parameter used in the low-dissipation Riemann
                                    solver. It determines the level of numerical dissipation being
                                    introduced in the pair-wise interactions. Tip:
 Default = 3.0 Tip: Reducing this value increases the amount of dissipation. The value
                                            of 3.0 is adopted from academic sources. CAUTION: Changing this value without an advanced
                                        consequences. | |
| adhesionCoeff | Scalar value that determines the strength of adhesion force
                                    of the fluid particles to the material. Tested range goes from
                                    0.001 to 2.0. Note: This is a numerical parameter, so it does
                                        not have its physical counterpart
                                        defined. Default = 0.0 | |
| contact_angle | This is the contact angle in degrees as seen from the fluid
                                        phase. Warning:
 Default = 90.0 Tip: For more
                                        information, refer to Contact Angle. | |
| fluidContactPhase | Use this command in the phase definition to track the amount
                                    of time the WALL or MOVINGWALL
                                    phase spends in contact with the specified fluid phase. The time
                                    data is written in the respective particle output file. Attention: This command is only valid for
                                            WALL and MOVINGWALL
                                        type phases, whereas the tracked phase can only be a
                                            FLUID. | |
| makesubphase | Setting this value to true enables more
                                    efficient treatment of the phases when executing the main GPU
                                    calculations. The performance gain increases as the number of
                                    the phases in the case increases. Tip:
 Default = true | |
| init_vel | This command can be applied to all phase types. Attention:
 Warning:  Assigning
                                        velocity boundary condition via init_vel
                                        will be removed in future version of nanoFluidX. Default = “0.0 0.0 0.0” |
