Probes
Probe particles are created in order to extract accurate post-processing information from a particular location, such as a FLUID or a WALL or a MOVINGWALL phase.
Commands
probes
    probe
        probe_type            volumeprobe
        probe_name            volumeprobeExample
        probe_cntr            "0.0 0.0 0.0”
        probe_rad             0.25
        probe_radodx          5
        probe_phase           3
        probe_shiftingaware   true
    probe
        probe_type            surfaceprobe
        probe_name            surfaceprobeExample
        probe_cntr            "0.0 0.0 0.0"
        probe_rad             0.5
        probe_radodx          9.5
        probe_thck            0.05
        probe_thckodx         3
        probe_nrmvec          "10.0 0.0 0.0"
        probe_phase           3
    probe
        probe_type            solidprobe
        probe_name            solidprobeExample
        probe_cntr            "1.0 20.0 3.0"
        probe_rad             1.0
        probe_radodx          15.5
        probe_phase           2
        probe_movewith        true
    probe
        probe_type            flowrateprobe
        probe_name            flowrateprobeExample
        probe_cntr            "1.0 -1.0 -100.0"
        probe_thck            0.2
        probe_thckodx         2.5
        probe_nrmvec          "0.0 1.0 0.0"
        probe_tanvec          "5.0 0.0 0.0"
        probe_points_file     filename
        probe_phase           3
}Definitions
| Command | Contents | SI Unit Example |
| probe_type | Type of the probe used Options
| probe_name | Probe name | |
| probe_cntr | Probe particle location Note: When
                                            flowrateprobe is comprised of
                                        multiple particles, probe_cntr represents
                                        a sort of reference point in cases where the probe is
                                        supposed to move. | |
| probe_rad | Radius of the probe particle Note: Influences the sample
                                        size. | Unit: [m] |
| probe_radodx | Radius of the probe as a function of Tip: For example,
                                        when probe_radodx is set as 3.0, this
                                        implies
                                            . Attention: If both probe_rad and
                                            probe_radodx are specified, the
                                        latter one takes precedence. Default = kernel cut-off size (3.0 for quintic spline) | |
| probe_phase | In cases of:
| probe_movewith | Command solidprobe points to a particular
                                    phase for monitoring, where this command determines whether the
                                    probe is also moving with that phase or not. Note: This command is applicable only to the
                                            solidprobe. Options
 Default = false | |
| probe_thck | This command specifies the absolute thickness of the probes. Commands flowrateprobe and surfaceprobe are effectively 2.5D-like entities, where their definition is 2D, but in order to function properly, they need to consider a certain space before and after them and require a thickness parameter. | Unit: [m] |
| probe_thckodx | Same as the above command, except that it specifies the probe
                                    thickness as a relative function of the kernel size. Tip: For example, when probe_radodx
                                        is set as 3.0, this implies
                                            . Default = | |
| probe_nrmvec | Vector specifying the surface normal of the probe. Flow passing in the same direction as this vector will be noted as a positive value flow. | |
| probe_tanvec | Specifies a vector which is co-planar with probe surface and
                                    at the same time defines the probe grid direction. Note: This
                                        command is optional. | |
| probe_points_file | Makes it possible to have a separate file with cloud point
                                    data (simple X, Y, Z coordinates; delimiter is space) and use it
                                    as a definition for the flowrateprobe probe
                                        particles. Note: Only applicable to
                                            flowrateprobe type. | |
| probe_shiftingaware | Enables the probes to consider the real convective velocity
                                    when using transport velocity or APD schemes. Tip: It
                                        is recommended that this option remains
                                        true. Default = true |
PROBE Output File
Probes can provide a broad set of information about the area which they are monitoring. This data can be torque or forcing data (solid probes only), mass or volume flow rates, pressure values, density, viscosity or velocity. Various applications require different measurements not just in terms of the monitored variable, but also in terms of time sampling or distinguishing the flow direction. In order to tackle all of these options, the PROBE output file can contain numerous columns.
- i - instantaneous information
- pta - periodic time average (averaged over the time between two outputs)
- TIME - time
- CNTR* - probe center
- CVEL* - probe center velocity
- NRMVEC* - normal vector of the probe
- NPART - average number of particles per 1dx thickness of probe
- oap - summation over all fluid phases
- abs* - absolute (does not consider probe velocity)
- rel* - relative (relative to probe velocity)
- *Vol* - Volume flow rate
- *Mss* - Mass flow rate
- *Co* - Component of flow in the probe normal direction
- *Flow - flow rate
Examples of column headers:
- pta_absVolFlow_1[m^3/s]
- Periodic time averaged absolute volumetric flow of phase 2.
- pta_relMssCoFlow_2[kg/s]
- Periodic time averaged relative mass flow in the direction of the probe normal for phase 2.
- pta_relVolFlow_oap[m^3/s]
- Periodic time averaged relative volumetric flow overall all phases (volumetric flow of all fluid phases).
- i_CNTR-Y[m]
- Instantaneous location of the probe center in Y direction.
- pta_absMssCoFlow_7[kg/s]
- Periodic time averaged absolute mass flow in the direction of the probe
                        normal for phase 7.Note: To clarify, the term periodic time average implies a value that is time averaged over the period between two required outputs (dt_phaseinfo). The ns_phaseinfo command defines the number of samples that will be taken over the period of dt_phaseinfo and then averaged to provide the periodic time average value in the output.
