Create Surface Mesh by Defining Size
Use the Surface tool to interactively create mesh on select surfaces by defining element size.
From the Mesh ribbon, click the
Surface tool.
- Select surfaces.
In the microdialog, select a surface meshing method and
define relevant parameters.
- Surface Deviation
- For mesh with smooth transition.
- Rigid Body
- For creating body-fitted mesh with minimum element count. It will create anisotropic mesh on curved surfaces based on the minimum size defined and apply defined size average / maximum size on flat surfaces. This is useful for Lattice Boltzman-based solvers where it is important to capture the shape of geometry with the least number of elements.
Click Mesh on the guide bar.
Surface mesh is created.
