Create Output on Section Cuts
Use the Section cut tool to select planes on which you would like to export the volume variables at given intervals.
Create section cuts.
- Optional:
Define section cut settings in the microdialog.
Figure 3.
Define the Output file format.
- Select either Ensight and/or H3D.
- Optional: Select Merge Output files to create one merged output rather than individual output files for each iteration.
In the microdialog, click
and specify the variables to export.
Edit the size of the section cut plane in the modeling window by completing one of the following:
- In the microdialog, click
and edit the sizing values.
- Click an edge of the plane and drag the arrow to lengthen or shorten the
selected side of the plane.
Figure 4.
Move the section cut plane in the modeling window.
- Select the section cut plane.
In the microdialog, select
- Use the graphical manipulator to move or rotate the section cut plane.
From the guide bar, complete one of the following:
- Select
to confirm your selection and continue creating section cuts.
- Select
to confirm your selection and exit the tool.
- Select
