Define Surface Output
Use the Surface tool to define surfaces on which you would like to export results at specific intervals.
Select multiple surfaces for a single instance of a surface output. The same surface can appear in multiple surface outputs simultaneously.
Create surface outputs.
- Optional:
Define surface output settings in the microdialog.
Figure 3.
Define the Output file format.
- Select either Ensight and/or H3D.
- Optional: Select Merge Output files to create one merged output rather than individual output files for each iteration.
In the microdialog, click
and specify the variables being solved for.
- Optional:
Import and export surface outputs.
- From the legend in the top-left of the modeling window, right-click the active surface output set and select Surface output table from the context menu.
In the dialog, select
to import surface outputs.
to export surface outputs.
For more information, see Import, Export, and Edit Output Controls. -
Use the legend in the top-left of the modeling window
to change the color of surface outputs.
From the guide bar, complete one of the following:
- Select
to confirm your selection and continue creating
surface outputs. - Select
to
confirm your selection and exit the tool.
- Select
