Batch Input File Format
Use the Batch Input file to run HyperLife in batch.
The HyperLife batch input XML file should be
contained within the
<HyperLifeInput> root tag, as shown below.
The tag has two attributes: profile and
version.<HyperLifeInput profile="Basic" version="2020.1">
</HyperLifeInput>Input files contain the following major sections:
- Input Files
- User Sets – Optional
- Derived Loadcase*– Optional
- Model Configuration
- Material Setup
- Load Map
- Evaluate
- Preferences
Restriction: Batch run xml is not supported for Spot and Seam Weld
Fatigue.
