User Sets
Multiple user sets of elements can be defined by providing a csv
file, which contains the element/node IDs.
<UserSet>
<UserSetFile entity_type="element"> C:/Users/xyz/Documents/Fatigue/RunHistory/Run1/CriticalElementSet.csv </UserSetFile>
</UserSet>
For each user set, a <UserSetFile> file element should be
provided with attribute entity_type=”element”/”node”.
A valid user set file contains the list of all the element/node IDs in the .csv file.
