Couplers
A Coupler entity defines an algebraic relationship between the degrees of freedom of two or three joints.
This constraint element may be used to model idealized spur gears, rack and pinion gears, and differentials as simple constraints that relate the displacements in a set of joints. Couplers can be used to specify relationships between translational, rotational, and cylindrical joints only.
Create Couplers using the Couplers Tool
- From the Model Browser, select the system to which the coupler is to be added.
From the Model ribbon, click the Couplers icon
to invoke the Couplers create/edit context.
A Couplers guide bar appears.Note: The Joint 1 collector is active by default. - Optional:
Select the Create Pair check box to create a pair
entity.
A coupler entity, like most of the entities that are created in MotionView, can be a single entity or a pair entity. Pair entities help to create models that are symmetric about the Z-X plane of the model. Their properties can also be symmetric about the Z-X plane (in other words, the Y property is mirrored). Asymmetry or symmetry of the coupler can be decided or specified when editing the created coupler.
Select the number of joints to constrain.
- 2 joints
OR
- 3 joints
- 2 joints
Select the first joint reference (Joint 1).
- Select a joint in the modeling window.
OR
- On the guide bar, click the Advanced
Selector
and make your selection in the Model Tree.
Note: When defining a pair coupler, use pair entities for Joint 1, Joint 2, and so on. - Select a joint in the modeling window.
Select the second joint reference (Joint 2).
OR
Selector
If the number of joints to constrain is 3, select a third joint reference
(Joint 3).
OR
Selector
- Optional:
Click
to reset the entity selections and select new entities.
Once the reference selections are made, create the coupler using one of the
following methods:
- Click
on the guide bar to create and orient the entity.
OR
- Click the
button that appears at the mouse location in the modeling window.
OR
- Click
to create the entity and exit the guide bar selections for this coupler.
Once the coupler has been added to the model, the corresponding coupler will automatically be displayed in the browser area.Note: By default, variables names of entities in MotionView follow a certain convention. For example, all coupler entities have a variable name starting with 'c_'. This is the recommended convention to follow when building models in MotionView since it has many advantages in model editing and model manipulation. - Click
Edit Couplers
If the Couplers Entity Editor is not currently
displayed, select the desired coupler by clicking on it in the Model Browser or in the modeling window.
The Couplers Entity Editor is automatically displayed.
Select the number of joints to constrain from the Type
option.
Note: If the selected coupler is a pair entity, first distinguish between the Left and Right tabs using the available drop-down menu to select the Side option, and then edit the properties. When defining a pair coupler, use pair entities for the joints.Tip: Use the Symmetry option to adjust the symmetry of the coupler's properties. Specifically, this option will determine if the pair entity is symmetric. If yes, then it is also responsible for specifying which side of the values of the pair entity (left or right) is to be used, by selecting Leading-Left or Leading-Right. Selecting any one side will make values of that side as “leader” and the values of the other side ("follower") will gray out and follow the values on the leader side.
Click on the Joint 1 collector and pick the desired
joint from the modeling window, or double-click the
Advanced Selector
to open the Model Tree (from which the desired joint can be selected).
- In the same manner, click the Joint 2 collector and pick the second joint for the coupler.
If the number of joints to constrain is set to 3, repeat the same step for the
Joint 3 collector.
Note: If any of the joints are cylindrical, select the type of the displacement to be controlled by using the drop-down menus located to the right of each selected joint on the Entity Editor (translational or rotational).
- In the case of a two joint coupler, enter in the displacement ratio between joint one and joint two in the Ratio 1 box, in the Properties menu. In the case of a three joint coupler, enter in the two displacement ratios between joint one and joint two, and between joint two and joint three.
Couplers Properties
Property | Description | |
Side | If a pair entity is defined, select each Side, to define properties separately. | |
Symmetry | Option used to define whether the coupler is symmetric and which side is the one responsible for properties definition. | |
General | ||
Label | Descriptive label for the entity. | |
Varname | Variable name of the entity. | |
ID | Integer identifier. | |
Active | Active state of the entity. True or False. Entity is deactivated if False. | |
Use Virtual | Make this a virtual constraint.* | |
Type | Type of Coupler (2 or 3 joints). | |
Joint 1 | First joint selection. | |
Jt 1 Coupling Axis | First joint’s coupling axis. It defines the type of displacement to be controlled and is automatically specified. In the case of a cylindrical joint, you should manually select the type of displacement (translational or rotational). | |
Joint 2 | Second joint selection. | |
Jt 2 Coupling Axis | Second joint’s coupling axis. It defines the type of displacement to be controlled and is automatically specified. In the case of a cylindrical joint, you should manually select the type of displacement (translational or rotational). | |
Joint 3 | Third joint selection (optional, this option is active only if Type 3 joints is selected). | |
Jt 3 Coupling Axis | Third joint’s coupling axis (this option is active only if Type 3 joints is selected. It defines the type of displacement to be controlled and is automatically specified. In the case of a cylindrical joint, you should manually select the type of displacement (translational or rotational). | |
Properties | ||
Ratio 1 | Displacement ratio between joint one and joint two. | |
Ratio 2 | Displacement ratio between joint two and joint three (active in the case of 3 joints type selection). | |
User-defined | Selecting the check box, allows specifying the properties of the coupler using user subroutines. | |
User expr | Expression defined with the USER solver function with parameters being passed to the user subroutine. | |
Use local file and function name | Activating the check box, enables the definition of properties through a file. | |
Local file | Local file selection for the subroutine. | |
Function Type | Function type selection. | |
Function name | Function name definition. | |
Note & Tags | ||
Note | Optional descriptive note. | |
Attachment Candidates | Add tags for the entity to use as possible attachments to Systems/Assemblies/Analyses. |
*Defines whether the constraint is virtual or regular. If the Use Virtual check box is selected, the constraint is implemented as a virtual constraint. Otherwise, the constraint is implemented as a regular algebraic constraint. See Comment 17 in Constraint: Joint for more information about virtual joints.
Use User-Defined Properties for a Coupler
If desired, define the coupler using the User-Defined tab, which will allow you to specify the properties of the coupler using user subroutines.
- From the Properties menu, click the User-defined properties check box.
Define the user subroutine.
