Motions
Use the Motions tool to create motions and to edit the initial conditions, displacements, velocities, and acceleration of joints.
Create Motions Using the Motion Tool
- From the Model Browser, select the system to which the motion entity is to be added.
From the Model ribbon, click the Motions icon
to invoke the Motions create/edit context.
A Motions guide bar appears.Tip: A new motion can be created from the Model Browser by right-clicking on the Model label (or any system/analysis of your choice) and selecting or by right-clicking Motions and selecting Add Motion. - Optional:
Select the Create Pair check box below the guide bar to create a pair entity.
A motion entity, like most of the entities that are created in MotionView, can be a single entity or a pair entity. Pair entities help to create models that are symmetric about the Z-X plane of the model. Their properties can also be symmetric about the Z-X plane (in other words, the Y property is mirrored). Asymmetry or symmetry of the motions can be decided or specified when editing the created motion.
Select whether the motion will be applied to joints or markers.
- On Joint
- Using Markers
If On Joint is chosen:If Using Markers is chosen: - Optional:
Click
to reset the entity selections and select new entities.
Once the reference selections are made, create the marker using one of the
following methods:
- Click
on the guide bar to create and orient the entity.
- Click the
button that appears at the mouse location in the modeling window.
- Click
to create the entity and exit the guide bar selections for this motion.
Once the motion has been added to the model, the corresponding motion will automatically be displayed in the browser area.Note: By default, variables names of entities in MotionView follow a certain convention. For example, all motion entities have a variable name starting with 'mot_'. This is the recommended convention to follow when building models in since it has many advantages in model editing and model manipulation. - Click
Edit Motions
A motion can be a displacement, velocity, or acceleration and can be applied to some joint types or between markers. Motion properties can be edited using the Entity Editor and are listed below.
Note: If the selected motion is a pair entity, first distinguish
between the Left and Right side in the Entity Editor, and then
edit the properties. When defining a pair motion, use pair entities for Joint, Marker, and
so on.
Tip: Use the Symmetry option to
adjust the symmetry of motion’s properties. Leading-Left indicates
symmetry with the left side being the leader and Leading-Right
indicates symmetry with right side being the leader. The other side ("follower") will gray
out and follow the values on the leader side. Asymmetric indicates the
properties as non-symmetric and both sides properties are editable.
Motion Properties
Property | Description | |||
General | ||||
Label | Descriptive label for the entity. | |||
Varname | Variable name of the entity. | |||
ID | Integer identifier. | |||
Active | Active state of the entity. True or False. Entity is deactivated if False. | |||
Use virtual | Represent the motion as a virtual constraint. | |||
Define Motion | Select the method for defining motion. | |||
On Joint | Define the motion on a joint. | |||
Joint | Select a Revolute, Translation or a Cylindrical joint on which motion has to be applied. | |||
Joint Type | Indicates the type of joint that is selected. | |||
Motion Type | Applicable for Cylindrical joint. Select the type of motion – Translational or Rotational. | |||
Using Markers | Define the motion using markers. The markers should belong to two different bodies. | |||
Marker 1 | Select the 1st marker on which motion is applied. | |||
Marker 2 | Select the 2nd Marker. The motion is applied on the 1st marker with reference to this marker. | |||
Direction | Select the direction along which the motion is applied. The choices offer applying motion either along translation or rotation direction of Marker 2. | |||
Property | Select the kinematic method for applying Motion. Displacement, Velocity or Acceleration. | |||
Properties | ||||
Type | Select the type of input for Motion. | |||
Linear | Indicates a constant value of motion. | |||
Value | A real value (or a reference data member of type real value). | |||
Curve | Indicates motion input using a curve. | |||
Curve | Select a 2D cartesian or parametric curve. | |||
Interpolation | Interpolation scheme to be used for the curve – AKIMA, CUBIC, LINEAR or QUINTIC. | |||
Independent variable | Solver expression to consider as the independent variable for the curve. | |||
Spline3D | Indicates motion input using a 3D spline. | |||
Spline3D (value) | Select a Spline3D entity. | |||
Independent variable X | Solver expression to consider as the first independent variable (X) for the Spline3D. | |||
Independent variable Z | Solver expression to consider as the second independent variable (Z) for the Spline3D. | |||
Expression | Indicates motion input using a solver expression. | |||
Expression | Solver expression that describes the motion. | |||
User defined | This is an alternate to the Type choices. Motion can be defined using a user subroutine. | |||
User expr | ||||
Use local file and function name | Optional. Provide a local file and function for the sub-routine. | |||
Local file | Select a file for the subroutine based on Function type. | |||
Function type | Select the type of file. DLL, Python, MATLAB or Compose. | |||
Function name | Name of the function within the subroutine file that needs to be called. | |||
Note: If local file and filename is not used, the solver may
use the subroutine based on its default search criteria. Refer the solver
reference guide to learn more.
Initial Conditions | ||||
Displacement initial condition | Applicable for Property as Velocity or Acceleration and type is not User-defined. Enter a value for the initial position of the motion. | |||
Velocity initial condition | Applicable for Property as Velocity or Acceleration and type is not User-defined. Enter a value for the initial velocity of the motion. | |||
Note & Tags | ||||
Note | Optional descriptive note. | |||
Attachment Candidates | Add tags for the entity to use as possible attachments to Systems/Assemblies/Analyses. |
