Create Symmetry Inputs
Use the Symmetry tool to create a design variable based on symmetry directions to be considered in the Generative Design exploration.
Note: For Generative Design explorations, only one plane symmetry will be
                    considered.
                From the Design Explorer ribbon, click the
                        Symmetry tool.
                In the Symmetry dialog, add rows to the table for each
                    symmetry plane to be considered by completing one of the following
                    options:
- Click None, X, Y, or Z.
 - Click Add Row to define a symmetry plane based on the selection of a plane in the modeling window.
