Add a Note
Add a note to a point on a curve.
From the Line Chart, Bar Chart, or Complex Chart ribbon, click the
Notes tool.
Figure 1. -
Hover over the curve to locate the coordinates to add the note to. Once the
point value is displayed, left-click to add the note to the curve.
Add a note to the window by clicking anywhere in the plot window. The note is displayed as View Note in this instance.
- To edit a note, double-click on a note to display the Edit Note dialog. Use this to edit the note's properties.
From the Edit Note dialog, click
to display the Entity Editor.
Figure 2. Entity Editor - Notes Tip: You can also use the Plot Browser to edit the note. Click on the note from the plot window to display its attributes in the Plot Browser.Tip: See Notes for more information on editing the note attributes.
